VACL Problem
ogormam2
Level 2
Level 2
Hi All,
I have implemented VACLs for capturing vlan traffic and all works fine until i add a second capture port on the switch. The CPU rises from about 10% to 75% and the latency when pinging a device on the local net goes from <1ms to over 40MS. once i shut the second capture everything returns to normal.
The VACLs are configured properly, I was wondering if there was a bug or could it be a problem with the truesight monitoring device. I am running ios 12.2.18 sxf8
thanks
tstanik
Level 9
Level 9
Here is the configuration guide for the VACL. Follow the configuration guide which will help you : http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080883ca2.shtml
