Verify Memory Cisco Switches
Malick MBAYE
I ordered a cisco switch with the following features:
8GB RAM
2GB Flash
When I received the equipment, I wanted to check if indeed it is the good material but I can not interpret the output of the orders.
thank you for helping me
5 Replies 5
Martin L
Correction:
2nd picture provides better info; 852 MB of flash drive space; 2 MB of NVRAM, and 4.1 GB of RAM
if u see K (a thousand), then count 3 spaces for Million, if u do not see K, then count 3 + 3 = get million.
Regards, ML
**Please Rate All Helpful Responses **
made a typo; updated previous post, and I like that show version | begin shortcut
Hello
Sorry for late
Thanks you very much for response.
Another question. How can i know if the switch delivered is authentic?
take the serial number from show version and use the following tool
https://cway.cisco.com/sncheck/?dtid=osscdc000283
Hope to help
Giuseppe
luis_cordova
Hi @Malick MBAYE ,
The show version command tells you those parameters
