Very simple telnet question
waztrix01
Lets say I have a router that is connected to four other routers on the following interfaces:
FastEthernet0/1: 192.168.1.1 (connected to a router with IP 192.168.1.2)
FastEthernet0/0: 192.168.2.1 (connected to a router with IP 192.168.2.2)
Serial0/0/0: 172.16.1.1 (connected to a router with IP 172.16.1.2)
Serial0/0/1: 10.10.1.1 (connected to a router with IP 10.10.1.2)
If I connect to this router through a console connection, and I use the routers telnet function to telnet to for example the 172.16.1.2 router - what IP address will this telnet request originate from (seeing as the router has 4 different IPs)? Will it change if I telnet to another router, say the 192.168.1.2 router?
smace
By default it will source from the interface closest to the destination. However, you can statically determine which interface you want it to source from by entering: ip telnet source-interface <interface id> in global configuration mode. After that, it will always source the outbound telnet session from that interface.
Hello
Just like to add the defined source address you select - Make sure its not being negated by any acls etc and its allowed access.
res
Paul
Kind Regards
Paul
chsarkar
Hello Waztrix, just login to the router and do telnet <IP address>. Make sure you able to ping the IP addresses. it wont change the src as long as you dont configure source-interface in global config.
Please rate if you find this useful.
