view power usage of a C9300 switch
jmcgrady1
I have a C9300-24t-a running 17.3.3. Is there a command to show the switches current power consumption? Not the usage per interface, but the overall use for the switch?  Show env power only shows the type of supplies and their status. It doesnt show realtime usage.
Reza Sharifi
As far as I know, the smaller, non-modular switches don't have a command to show the overall usage of power by the switch.
the C9300-24t-a model does not have PoE does it?, only the 24P and 24U models have.
therefor no power info per interface.
is table-22 (power consumption under different traffic load) in the datasheet provide sufficient for your need?
Cisco Catalyst 9300 Series Switches Data Sheet - Cisco
