Viewing MAX-reseved-bandwidth on Cisco 7600 router
sarahr202
Level 5
Level 5
Hi everybody
I have been searching a command that will shows us the max-reseved bandwidth ( In the context of QOS) on cisco 7600.
I appreciate your help
ciscoR1#show version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.1(3)S5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 12-Feb-13 13:17 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 15.1(3)S5, RELEASE SOFTWARE (fc2)
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I'm uncertain, but on a 7600 with 15.x IOS, it's likely QoS is following the HQF changes, and if so, max-reserved-bandwidth has really been deprecated.
Joseph W. Doherty
Disclaimer
Posting
