Virtual Switching
taufeeq taufeeq
I have WS-6509-E . How do I find whether it supports VSS or not ?
Thanks in advance.
Taufeeq?
2 Accepted Solutions
Seb Rupik
Hi Taufeeq,
Depends on the supervisor you have in your chassis. It needs to be one of the following:
cat6000-VS-S720-10G/MSFC3
cat6000-VS-S2T
...and an IOS release above 12.2(33)
cheers,
Seb.
Please refer the below URL and look for hardware requirements.Wolud suggest to use IOS version s72033-ipservicesk9_wan-mz.122-33.SXJ1
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.pdf
https://www.google.co.in/?gws_rd=cr&ei=vWLBUpmIEIaSrgfS8YGIBQ#
Sathvik K V
Seb Rupik
Hi Taufeeq,
cat6000-VS-S2T
cheers,
Seb.
Sathvik K V
