Visio Stencil for 3750-24FS-S
Canuck
Does anyone know where I can get the Visio stencil for the 3750-24FS-S (24 port 100Mb MTRJ). I downloaded the 3750 stencil pack but unfortunately this specific model is not in there. Thank you.
Reza Sharifi
I am not sure if you will be able to find that stencil as that product is over 10 years old now.
MTRJ is very old.
Julio E. Moisa
Here you will find the visio stencil for this model:
https://www.cisco.com/c/en/us/support/switches/catalyst-3750-24fs-switch/model.html
Visio Stencil (4 MB .zip file)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks, Julio.. that is the folder I downloaded and unfortunately the 24FS-S model isn't in there.
