VLAN 1 Issue
jaydenle
Community Member
Hi All,
I recently setup new 3750x switches in my network and created vlans to expand my network. I assigned an interface Gi1/0/1 ip 192.168.1.253 so it act as an gateway for my VLANs. The vlan works fine in this case but only problem is that my default vlan 1 does not have any connectivity. What have i done wrong? i have attached the config of my switch. Thanks for your help.
interface GigabitEthernet1/0/1
description Default Gateway for VLAN
no switchport
ip address 192.168.1.253 255.255.255.0
interface GigabitEthernet1/0/2
switchport mode access
speed 1000
duplex full
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
switchport access vlan 4
interface GigabitEthernet1/0/13
switchport access vlan 2
speed 100
duplex full
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
power inline port priority high
flowcontrol receive on
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
description ***Trunking Ports***
switchport mode trunk
speed 1000
duplex full
interface GigabitEthernet1/0/24
speed 1000
duplex full
interface GigabitEthernet1/1/1
description ***Uplink-to-Warehouse-Cisco3750G***
udld port
storm-control multicast level 50.00
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.2.254 255.255.255.0
ip helper-address 192.168.1.101
interface Vlan4
ip address 192.168.4.254 255.255.255.0
interface Vlan8
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.255.1
ip route 192.168.0.0 255.255.0.0 192.168.1.254
ip route 192.168.1.0 255.255.255.0 192.168.1.254
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password bmw328i
login
line vty 5 15
password bmw328i
login
end
Sandeep Choudhary
HI Jayden,
Why are you using IP ADDRESS for interface GigabitEthernet1/0/1.
Instead you can use this address for int vlan 1 and then make shut, not shut.
Try this :
Int gig1/0/1
No ip address
no duplex full
int vlan 1
ip address 912.168.1.253 255.255.255.0
Reagrds
please rate if it helps.
Just as a note here, I'd recommend you NOT use vlan 1 for your configuration.  Though it may not be of immediate concern to you for this task, it is a good practice to keep that vlan shut down and pruned from trunk links.  Since you aren't explicitly defining a vlan as native on your trunk, the switch defaults to vlan 1 as native, which exposes you to some security vulnerabilities.
I know, I know.....that's outside the scope of what you're trying to get done, but it's good to know for future reference.
***Please rate helpful posts***
