VLAN Access map problem
radarbackwards
Scenario is :
vlan 210 must not access vlan 250
vlan 210 can access other vlans - 200, 914 and vlan 68
i tried to permit the addresses of the 3 vlan - 200,914 and 68 on vlan 210 filter, but what happened is it cant also access the 3 other vlan eventhough it is permitted
vlan 200 -  192.168.200.0
vlan 91 - 192.168.91.0
vlan 68 - 192.168.68.252
ip access-list extended VLAN-FILTER210
permit ip 192.168.210.0 0.0.0.255 192.168.250.0 0.0.0.255
ip access-list extended TRAFFIC-200-914-68
permit ip 192.168.210.0 0.0.0.255 192.168.200.0 0.0.0.255   <------- Network Address of VLAN 200
permit ip 192.168.210.0 0.0.0.255 192.168.91.0 0.0.0.255     <------- Network Address of VLAN 91
permit ip 192.168.210.0 0.0.0.255 192.168.68.252 0.0.0.3     <------- Network Address of VLAN 68
vlan access-map VLAN-FILTER-210 20
match ip address VLAN-FILTER210
action drop
vlan access-map VLAN-FILTER-210 10
match ip address TRAFFIC-200-914-68
action forward
vlan filter VLAN-FILTER-210 vlan-list  210
what did I do wrong?
Why are you using a VACL to filter inter vlan traffic ? a VACL is for filtering intra vlan traffic and for inter vlan traffic it is best to use a RACL applied on the SVI.
Alain
6 Replies 6
Eduardo Aliaga
Level 4
Level 4
It seems your config is OK. Could you please post the result of "show vlan filter" "show vlan access-map" "show vlan access-list" ?
CORE_SWC#sho vlan access-map
Vlan access-map "VLAN-FILTER-210"  10
  Match clauses:
    ip  address: TRAFFIC-200-914-68
  Action:
    forward
Vlan access-map "VLAN-FILTER-210"  20
  Match clauses:
    ip  address: VLAN-FILTER210
  Action:
    drop
VLAN Map VLAN-FILTER-210 is filtering VLANs:
  210
and 1 more thing guys
I replace the network addresses with
permit ip any any
and now it can ping other network addresses, how do i allow network addresses specifically? i tried to specifically add the said network addresses but it wont do, i dont know what did i do wrong
Alain
hi cadet, thanks for the enlightenment, for clarification, i can use VACL if i want to block the telnet/rdp on the whole vlan 200 network right?
Yes you can use a VACL to filter traffic between hosts in the same VLAN.
Alain
