Vlan blocking Cisco L3 Switch (4948 E-F)
Tamas86
Hi Everyone!
I would like to enlist your assistance in a question which I have been trying to find an answer to for about 3 days.
There is a SW to be tested. For us to be able to test it, the following test environment has been set up (please see the picture below).
2 pieces of VLAN network:
  • No. 20, LAN connection of the company
  • No. 40, LAN connection of the test server
The test server is located at the IP address of 192.168.4.1 (192.168.4.1/24), DHCP runs on it (DHCP range is depicted in the picture). The company router has the IP address 192.168.2.1 (192.168.2.1/23) and it runs DHCP too (DHCP range is depicted in the picture).
The reason why this is of highest necessity is because the SW to be tested gets certain devices to boot through pxe and LAN No.40 is the closest connection of the server.
Switches L2 are configured in such a way that ports ranging from 1-12 are assigned to the company LAN, the rest from 13-24 are assigned to the test LAN. Switches L3 works the same way as L2. The system and the setup itself operate perfectly enabling us to test the SW in this particular environment however we would intend to make some changes.
(Layer 2 switch: cisco 2960
Layer 3 switch: 4948 e-f)
I must decouple VLAN No. 20 from No. 40 in order to block any interoperability between the two resulting in the devices in these different networks won’t see one another (neither ping nor anything else).
Several configurations have already been tried out thus far, neither of them has worked out. I have also created an IP access list but this one did not work either. What can go wrong with the configuration? I upload the default configuration without ACL because it must be faulty and then I delete them.
Can you please give me a hand in finding a solution for how I could separate these two networks from each other?
Your help is truly appreciated and thank you in advance!
L3 switch config:
kozpont2#sh run
Building configuration...
Current configuration : 6257 bytes
version 15.0
no service pad
service compress-config
hostname kozpont2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip routing
ip dhcp snooping vlan 20,40
ip dhcp snooping
ip vrf mgmtVrf
vtp mode off
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 20
name hadri
vlan 40
name aiken
vlan 98
name native vlan
ip tftp source-interface FastEthernet1
ip vrf forwarding mgmtVrf
ip address 10.0.0.1 255.255.0.0
no ip route-cache
speed auto
duplex auto
interface GigabitEthernet1/1
switchport access vlan 20
switchport mode access
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
switchport access vlan 40
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
interface TenGigabitEthernet1/49
ip dhcp snooping trust
interface TenGigabitEthernet1/50
switchport mode trunk
interface TenGigabitEthernet1/51
interface TenGigabitEthernet1/52
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan20
no ip address
ip helper-address 192.168.2.1
no ip route-cache
interface Vlan40
no ip address
ip helper-address 192.168.4.1
no ip route-cache
no ip http server
no ip http secure-server
no cdp run
line con 0
stopbits 1
line vty 0 4
login
end
kozpont2#
We have the solution! The error is on the test server, it does not separate the traffic of the 2 VLANs, so it does not work correctly. The problem is caused by Ubuntu based SW running on the server. This SW has some restrictions, so any changes I make are rolled back by the server, or not applied properly.
I will contact the developer to find the error . The CISCO  switch works perfectly as per the configuration which has been tested as well. (VLAN side No. 20 of the test server has been removed from the switch.)
11 Replies 11
NetworkDave
Tamas86,
You want VLAN20 and VLAN40 to be isolated from each other.
Have you tried removing the inter-VLAN routing between the VLANs?
The devices that use PXE, which VLAN(s) are they in?
Which interfaces are connected to the router and server?
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
Hi NetworkDave!
The device using PXE is located in VLAN No. 40.
The closest connection of the test server (192.168.4.1) shown on the picture is connected to the interface "TenGigabitEthernet1/49" on switch L3.
This connection of the test server feeds the devices connecting to VLAN No. 40 with full network access.
This server also has an "outer" connection which is wired into the GigabitEthernet1/1 interface (into VLAN No. 20, meaning it has access to 192.168.2.1)
As far as I know the test program being tested works in such a way that it does not let any traffic through the two LANs. Thus the need for the two interfaces.
The company router is connected to switch L3 through TenGigabitEthernet1/52.
Tamas86,
Thanks for providing the requested information. From your first post, It was thought that you wanted to isolate the VLANs. It appears that the VLANs are already isolated.
What is it that you currently need help with?
Joseph W. Doherty
Hmm, I don't see how anything gets passed between VLANs 20 and 40 now.  You L3 switch doesn't have IPs on its SVIs and you only note one (?) IP on the "company router".
BTW, it appears your L3 switch support VRFs.  If so, you could also create a test VFR and place VLAN 40 in it.
Hi Joseph W. Doherty!
Unfortunately, I don't have much experience in configuring cisco devices, but so far I've managed to get everything working. I have tried to do this with the minimum configuration I can think of. Looking through several documentation this seemed to work. I will try the VRF you suggested. Could you perhaps show me an example of how to set this up?
Ah. actually you already have an example in the config you posted, i.e.:
ip vrf mgmtVrf
You define a VRF and than you place interfaces in it.
You're right, I missed it
I know I am late but better late than never,
can you elaborate please?
Hi MHM Cisco World!
Isolating VLAN No. 20 and No. 40 from each other did not work. Although the L3 switch configuration seemed to be correct. I managed to find the error. The test server is causing the problem, the CISCO switch is working properly
Tamas86
Thanks for everithing taking the time to look into the problem and trying to help!
