Vlan management configuration
malfury77
I try to confire the vlan management on cisco packet tracer but i can't do it... and i don't know why...
here is a very simple architecture
I must surely be doing something wrong or forgetting something since whether it's the router or the PC I can't ping 192.168.99.253
How to configure this **bleep** vlan management
Thank you
M02@rt37
Hello @malfury77
on the Swtich, add ip default-gateway command:
ip default-gateway 192.168.99.254
Best regards
I try my lab on the other PC and it works... I write the same command however... I forgot yesterday to note "ip default-gateway" on the diagram my mistake sorry
Could be a problem on my machine, stupid question but can the Windows firewall block certain things in the software?
Thank you
Yes @malfury77
Try to desactivate Windows Firewall and re test.
Best regards
