VLAN Mapping / Translation - Need list of supported hardware/software
I am looking to find out which series of switches supports VLAN mapping (or translation depending on who you ask).  I attempted a search online and on Cisco's site but have had little luck.   Are there any good resources online for finding this out easily?
Mark Malone
Hi you could try the feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
that looks like it is a great tool for software releases (which is half my problem).  Is there something similar for hardware support?
From my research, it looks like a 3750 might be the cheapest option but this might be outdated info.
Thank you for the link by the way!
havent seen one for hardware really
this is all the tools Cisco have currently
http://www.cisco.com/c/en/us/support/web/tools-catalog.html
when im trying to find hardware information i just put the model platform into google and put data sheet after it , Cisco release data sheets for each platform not sure if theres a central location though for them
example i just put 3750 data sheet into google the first link came up was
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/product_data_sheet0900aecd80371991.html
Thank you Mark!
