VLAN MAPPING
sandeep28585
Frequent Visitor
Frequent Visitor
Hi I faced an issue where i van apply the vlan mapping on the physical interface but not on the port channel.With physical interface the vlan transaltion working fine but when i add the physiacl ports into portchannel it fails.Any idea what is missing , appreciate if you guys can answer.
7 Replies 7
Leo Laohoo
Post the command & the error message encountered.
Sorry typo error , I mean to say i added the physical ports into a port-channel but after the addition vlan mapping did not worked.
Post the command entered and then, if there are no error messages, post the complete output to the following commands:
1.  sh int po<BLAH> status;
2.  sh interface trunk; and
3.  sh log
int gx/x
switchport vlan mapping enable
switchport mode trunk
switcport mode trunk allowed vlan
channel group 101 mode on
but when i did the sh run int po 101 "switchport vlan mapping enable" was not there and i was not able to see the mac address on the vlan which i translated.
But when i used only the physical interface i was able to see the mac address . The switch where i was configuring is 6500
Sorry i cant share the output as this is related to my client and we are not authorised to share the output.
Are you doing Q-in-Q?
No i am not doing any Q in Q. Only  l2 vlan translation .
Any suggestions ?
