vlan port lost connection after reload
yaredo70
Hi All,
I recently have an issue with some of the switches lost the VLAN connection after the switch reload. sh int command showed interface down and protocol down. I have to assign the VLAN after reboot. any idea why the switch lost its VLAN?
8 Replies 8
 what is the switch model and IOS version ?
it happened on different models 2960X, 3560CX the IOS version - ...152-7.E8.bin
assign vlan ? can you more elaborate
the vlan SVI is down ?
the VLAN SVI IP is disappear ?
the port vlan assign disappear ?
the vlan not show in show vlan ?
Hello
Sorry for the late reply.
The port VLAN assign disappear after the switch reboot.  I have to run SW#switchport access vlan 999 command on that port
The vlan disappeared from vlan db' check vtp  the vtp server push vlans list  not include this vlan.
How do I solve it if that is the issue? please include the commands. Thanks.
In vtp server of vtp domain' only add
Vlan x
This make vtp push the vlan and even if the sw reboot it always have this vlan in db and it will not disappear from port
Martin L
is  VTP  in transparent mode ? if so, then all vlans are stored locally in start up config; if not, vlans are stored in vlan.fat file on flush of switch; if VTP mode is client, you cannot add or remove vlan x; it must be done on VTP server switch or change VTP client to server mode.
Regards, ML
**Please Rate All Helpful Responses **
