VLan Tag Sonicwall and Catalyst 2960 Series
josegarcia123
I have a Sonicwall NSA3500 and a 2960-48TT-L I would like to set up VLAN tags so the Sonicwall would control the VLAN is that possible?
Thank you
Jon Marshall
Carlos
If the SonicWall can do 802.1q on it's NICs and you can create subinterfaces for each of the vlans on the SonicWall then yes it is possible. It is a failry common setup with ASA firewalls.
If you are asking whether the SonicWall can do 802.1q tagging then no idea this is a Cisco forum after all
Edit - looks like the SonicWall, or at least certain models, can do 802.1q. Attached is a pdf showing how to configure 802.1q between a Cisco switch and the SonicWall.
Jon
