VLAN tagging and prioritization
jradke
Cisco 3560G-24TS-S
I need to provide layer2 connectivity for a local business with several vlan's and separate priority for each. I don't know what their switch/router configurations look like and ultimately it shouldn't matter because I'm trying to keep my transport piece relatively transparent to them. However, I do need to keep their traffic separated as they have indicated.
I'm providing connectivity to three locations with three vlans along with bandwidth limiting. How do I tag the vlans and set a priority for each vlan?
I?m not sure how I can provide this ability because of this info I found on Cisco:
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00801e85dd.html#90021
?You configure QoS only on physical ports; there is no support for it on the VLAN or switch virtual interface level.?
How do you suggest I provide priority for their network traffic?
Thanks for any advice you can offer!
-JGR
7 Replies 7
Collin Clark
You can't prioritize by VLAN tag (that I've ever heard). As long as you configure QoS correctly and don't oversubscribe the uplink, you'll be OK.
I'm doing rate-limiting on the customer, they only subscribe to a certain amount of bandwidth. There is no other way to classify the traffic that I can see except by vlan. Doesn't it make sense to provide QoS on a particular VLAN? That's what cisco does for voip phones! Force10 networks can do it in their box equivalent to the 3560. Any other suggestions?
What I do is classify the data coming in (on the customers interface on my switch) and then police it.
and you classify the data based on?
IP subnet, port/protocol, or ?
can you share an example?
Here's an example
This example shows how to create a policy map and attach it to an ingress interface. In the configuration, the IP standard ACL permits traffic from network 10.1.0.0. For traffic matching this classification, the DSCP value in the incoming packet is trusted. If the matched traffic exceeds an average traffic rate of 48000 bps and a normal burst size of 8000 bytes, its DSCP is marked down (based on the policed-DSCP map) and sent:
Switch(config)# access-list 1 permit 10.1.0.0 0.0.255.255
Switch(config)# class-map ipclass1
Switch(config-cmap)# match access-group 1
Switch(config-cmap)# exit
Switch(config)# policy-map flow1t
Switch(config-pmap)# class ipclass1
Switch(config-pmap-c)# trust dscp
Switch(config-pmap-c)# police 48000 8000 exceed-action policed-dscp-transmit
Switch(config-pmap-c)# exit
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# service-policy input flow1t
class-map match-all c_Outbound
match access-group 101
class-map match-all c_MarkDSCP
match access-group 102
class-map match-all c_Inbound
match ip dscp 60
policy-map p_Outbound
class c_Outbound
police 1528000 8000 exceed-action drop
policy-map p_MarkDSCP
class c_MarkDSCP
set dscp 60
policy-map p_Inbound
class c_Inbound
interface FastEthernet0/11
switchport access vlan 110
switchport mode access
service-policy input p_MarkDSCP
spanning-tree portfast
interface FastEthernet0/12
switchport access vlan 12
service-policy input p_Outbound
service-policy output p_Inbound
access-list 101 permit ip host 12.18.16.17 any
access-list 102 permit ip any host 12.18.16.17
Thanks for the example Ceclark!
I tried the top configuration and it works! Any idea though why these stats don?t show anything?
GVS-3560#sho policy-map int g0/11
GigabitEthernet0/11
Service-policy input: flow1t
Class-map: ipclass1 (match-all)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group 1
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
Also, I'd like to do fixed port based rate limiting but that doesn't seem to be available on the 3560? How can I limit both inbound and outbound on one particular port?
Thanks again!
-JGR
I'm not sure why you do't see anything and to be honest, I've never looked at mine (I need physical access to the switch)! I tested it to make sure it worked, but never looked at the stats. The script above should limit both in and out. The second part is for egress. It first marks, then polices, since it's not trusted initially.
set dscp 60 !-- Tags all incoming (egress)traffic
