VLANS and intervlan Routing
nagarjunaz
I am trying to create a new LAB setup for my office. I have an HP 5500 Layer 3 switch behind ASA 5500 firewall. Firewall is connected to the corporate network. I created 3 Vlans for each platform.( Vlan 1 , Vlan 800, 801). When i assign server under Default VLAN 1 i am able to reach my corporate network. But when the same server is in VLAN 800 i am not able to reach corporate network.. Basically i am able to reach corporate network when my VLANS are in default VLAN 1 only. I created VLAN interfaces and assigned an IP address for all the VLANS. Default route was pointing to firewall.
I was wondering what the problem can be ?
Where is the intervlan routing being performed? What mode is the Fw running (routed/transparent)
Have you set up the logical vlans on the FW?
Is ip routing enabled on the Hp switch?
Can you post the config if the FW
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Inter VLAN Routing is done at HP L3 switch. By default IP routing is enabled on L3 HP switches unlike cisco where we need to enable routing manually.
When routing is enabled on L3 HP switch is it required to configure logical VLANS on FW ?
Appreciate your help
