ME3400 Layer 3 can't ping host to host inside same vlan
ok we have an me3400 that handles several of our wan vlans coming in, and is also connect to our vlan 1 (which is our local lan) i have created a new vlan 120 for our new server equipment and the associated subnet 192.168.120.X
no problems, and all the new servers can talk to vlan 1, and on out to the internet no problems.... but they cant ping each other , they can ping the outside and the gateway, but not each other... already checked -- no acls in place and the windows firewall is disabled
any help would be greatly apprecieated... we are trying to get this stuff online asap -- as its holding up our server build out
config::
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2009.05.19 12:40:00 =~=~=~=~=~=~=~=~=~=~=~=
3400_CH>en
Password:
3400_CH#show run
Building configuration...
Current configuration : 2556 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 3400_CH
boot-start-marker
boot-end-marker
enable secret 5 $1$xnWP$SjbxigGgqIAE8/o5gjJVM1
enable password 7 01100F175804
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
--More-- !
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 120
name DataCenter
vlan 180-182,186
interface FastEthernet0/1
description to Opteman Network
switchport mode trunk
interface FastEthernet0/2
description to Internet
--More-- speed 100
duplex full
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
--More-- interface FastEthernet0/13
switchport access vlan 120
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
--More-- !
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
port-type nni
interface GigabitEthernet0/2
port-type nni
interface Vlan1
description Local Network
ip address 192.168.101.252 255.255.255.0
--More-- interface Vlan120
description Datacenter Network
ip address 192.168.120.1 255.255.255.0
interface Vlan181
description Opteman ptp to Library
ip address 192.168.150.1 255.255.255.252
interface Vlan182
description Opteman ptp to Fire Station #3
ip address 192.168.150.9 255.255.255.252
interface Vlan186
description Opteman ptp to Maintenance Complex
ip address 192.168.150.5 255.255.255.252
router rip
version 2
network 192.168.101.0
network 192.168.120.0
network 192.168.150.0
no auto-summary
--More-- ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.101.254
control-plane
line con 0
password 7 0758784F5A010A5045
line vty 0 4
login
line vty 5 15
password 7 1511021F07257A
login
end
3400_CH#show vla
randyjoh1
Hi Anthony,
I am not a pro yet on this box, but I have run into your problem before. In order for the servers to talk on the same VLAN on the 3400, the vlan must be identified as a 'community' vlan. By default in the 3400, the ports are isolated VLANS and cannot talk to each other. Something like:
#config t
#vlan 120
#name servers
#uni-vlan community
I am not sure if you need to delete and reenable your server VLAN. I hope this helps.
Randy
This was 100% my issue.  Many thanks!
HI,
The default VLAN state for all VLANs created on a ME 3400 switch is UNI isolated VLAN. Local switching does not occur among UNIs on the switch that belong to the same UNI isolated VLAN. This configuration is designed for cases when different customers are connected to UNIs on the same switch.
Whereas local switching is allowed among UNIs on the switch that belong to the same UNI community VLAN.If UNIs belong to the same customer, and you want to switch packets between the ports, you can configure the common VLAN as a UNI community VLAN. There is no local switching between ports in a UNI community VLAN and ports outside of the VLAN. The switch does not support more than eight UNIs in a UNI community VLAN.
So you need to have the below config to achieve the purpose.
#conf t
vlan 120
name DataCenter
uni-vlan community
end
* Plz rate this if the info was helpful.
Thanks & Regards,
Vignesh R P
