05-09-2007 01:10 PM - edited 03-05-2019 03:58 PM
I have cisco WS-C3550-24-SMI running ip routing.
I have three customers and they fall in their own valns as listed:
interface FastEthernet0/10
switchport access vlan 10
no ip address
spanning-tree portfast
interface Vlan10
description cust2
ip address 1.1.6.37 255.255.255.252
ip access-group inbound in
ip access-group outbound out
interface FastEthernet0/11
switchport access vlan 11
no ip address
interface Vlan11
description cust3
ip address 1.1.7.41 255.255.255.252
Than I have another vlan the one pointing to router
switchport access vlan 14
no ip address
load-interval 30
duplex full
speed 100
interface Vlan14
description wireless
This all worked fine. The problem is there is traffic on physical ports and I can't see traffic on VLAN. For example when I execute this command show interface vlan 14. I just some kb traffic while there is more than 10Mb traffic on Fe 0/1. Same for other vlans.
Also access-lists are not working proprely. How do you guys use switches when you need to use your switch as intervlan router and access-lists on vlan or port bases?
05-09-2007 10:34 PM
Bear in mind that you will only get traffic going across the vlan interface if it needs to be routed. So a server within the vlan communicating with another server in the same vlan will not traverse the layer 3 vlan interface.
You should apply access-lists to your vlan interfaces if you want to filter traffic between vlans. Best way to think of it is
Inbound access-list on vlan interface is traffic coming from that vlan and being routed off to another destination.
Outbound access-list on vlan interface is traffic coming from a remote destination and being routed onto the vlan.
Jon
05-09-2007 11:26 PM
Hi, Thanks for reply.
My customer traffic is internet traffic and being forward/routed to upstream router. As you said I will see all L3 routed traffic in vlan interface but in my case I can't and I don't know exactly why it is.
I don't want to filter traffic between vlan, I wana filter all internet traffic which is being routed to upstream L3 on vlan interfaces for individual customer vlan.
