VLANS trunks doesn't work
punasup
Switch0 configuration:
S0(config)# vlan 10
S0(config-vlan)# name dev
S0(config-vlan)# vlan 20
S0(config-vlan)# name tech
S0(config-vlan)# exit
S0(config)# interface f0/1
S0(config-if)# switchport mode trunk
S0(config-if)# interface f0/5
S0(config-if)#interface f0/6
S0(config-if)# switchport mode access
S0(config-if)# switchport access vlan 10
Switch1 configuration:
S1(config)# vlan 10
S1(config-vlan)# name dev
S1(config-vlan)# vlan 20
S1(config-vlan)# name tech
S1(config)# interface f0/1
S1(config-if)# switchport mode trunk
S1(config-if)# interface f0/18
S1(config-if)# switchport mode access
S1(config-if)# switchport access vlan 20
PCA : 192.168.10.2 PCB : 192.168.20.2
Problem: I can't ping the PCB from the PCA. I don't understand what is missing, it's a simple configuration and I followed a tutorial.
Thanks!
balaji.bandi
where is the Layer 3 SVI confifgured for the Gateway for this subnet for VLAN 10 and VLAN 20 ?
PCA  what is the Gateway or what switch has this ?
PCB  what is the Gateway or what switch has this ?
Try below config
config t
Interface vlan 10
ip address 192.168.10.254 255.255.255.0
no shut
Interface vlan 20
ip address 192.168.20.254 255.255.255.0
no shut
ip routing
setup your PCA  gateway as 192.168.10.254 and PCB to 192.168.20.254
check PCA able to ping .254
Test now.
BB
balaji.bandi
Try below config
config t
Interface vlan 10
no shut
Interface vlan 20
no shut
ip routing
Test now.
BB
Seb Rupik
Hi there,
You have no Layer3 interfaces to provide a mechanism for the subnets to reach eachother. What you need to do is replace one of the Layer2 switches with a multi-layer switch and configure Layer3 SVIs on it:
int vlan 10
int vlan 20
PC A needs to have its default GW set to 192.168.10.254 and PC B DGW set to 192.168.20.254.
cheers,
Seb.
punasup
Thank you very much, it works and I understand.
