Voltage In Cisco Switch (PoE)
silver.root
I want to learn how a Cisco PoE switch sends the voltage on its ports ...
I plug in two IP cameras. One camera runs, if you power it from a transformer, 5VDC at 800mA. The other, if you power it from a transformer, runs 9VDC at 1000mA ...
How does a Cisco PoE switch know how much voltage it's supposed to be sending??
Is there a negotiation process  between the POE switch and the POE device ??
Collin Clark
Yes there is a negotiation process-
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/power_over_ethernet.html
PoE is for IPPhone and those PoE powered devices?
