vPC cluster problem to VSS cluster using Port-Channels
Dennis Leon
We have a vPC cluster of two Nexus 7009 that needs to be connected with a VSS cluster of two Catalyst 6509s. The VSS has been working fine for a while and the vPC cluster is new equipment.
Attached there is a detailed diagram of the connections; the VSS cluster connects the interfaces Ten1/2/8 and Ten 2/2/8 using the PortChannel 28 going to the the vPC cluster to the interfaces Eth 4/18 of each switch.
Both the vPC and the VSS are well configured; last night we tried to brought up the connection between the two clusters but only the first interface comes up within the etherchannel; the secondary one did not come up and shows (not receiving LACP packets).
We know Layer 1 is fine because if we remove the interface from the EtherChannel it does come up; but causes some STP loop and bring the network down; thus the solution is to form a EtherChannel.
At the VSS Clúster we see LACP packets being sent with sh lacp counters but we DO NOT see LACP packets being received in the interface of the secondary Nexus.
Right now, this is not possible to troubleshoot since it is a production enviroment; so I'm looking for problems with the configuration or recommendations to follow in order to apply them tomorrow night during a new maintenance window.
These are the configurations:
#######vPC cluster of Nexus 7009######
--N7K-1--
interface port-channel418
  description Uplink 20 GE hacia VSS
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1,4,10,17,35,37,39,60,63,100,112
  switchport trunk allowed vlan add 120,149-152,154-160,163-164,170
  switchport trunk allowed vlan add 172,190,200,801,900,905,910,920
  switchport trunk allowed vlan add 925,960
  spanning-tree port type network
  vpc 418
  no shut
interface Ethernet4/18
  description Uplink 10 GE hacia VSS-1 Ten 1/2/8
  switchport
  rate-mode dedicated force
  udld aggressive
  channel-group 418 mode active
  no shutdown
--N7K-2--
  switchport
  vpc 418
  description Uplink 10 GE hacia VSS-2 Ten 2/2/8
  switchport
  udld aggressive
  no shutdown
interface TenGigabitEthernet1/2/8
description CONEXION HACIA ETHERNET 4/1 NEXUS 7K PRIMARIO CAP
switchport
switchport trunk allowed vlan 1,4,10,17,35,37,39,60,63,100,112,120,149-152
switchport trunk allowed vlan add 154-160,163,164,170,172,190,200,801,900,905
switchport trunk allowed vlan add 910,920,925,960
no shutdown
udld port aggressive
storm-control broadcast level 1.00
channel-group 28 mode active
interface TenGigabitEthernet2/2/8
description CONEXION HACIA ETHERNET 4/1 NEXUS 7K SECUNDARIO CAP
switchport
no shutdown
interface Port-channel28
description Trunk hacia Switches NEXUS 7K CAP
switchport
Derek Zhang
any logs that you saw when the etherhcnael failed to establish the neighbor?
Looking at your configuration:
" spanning-tree port type network" on N7K indicates you enable the Bridge Assurance feautre but not on VSS side.
Try with type normal if BA is not needed between VSS/N7K.
Thanks for the reply Dazhi; actually we did enable that after some attempts but at the beginnning it was not configured.
I saw that in a config guide, but I'm not really sure what is the effect of that command.
I'm attaching a debug from the N7K that was able to capture.
Spanning-tree port type nework will enable bridge assurance. It is bi-directional BPDU. Since you are using vPC to the VSS, it is not recommended to enable BA over vPC port-channels. You should use Normal like what Derek said.
Secondary, you are using UDLD aggressive, this is also not recommended. UDLD normal should do the job on fiber link. Can you check the interface and post the output?
show interface e4/18 !!! on the Nexus
show interface ten1/2/8 !!! on the C6K
show interface ten2/2/8 !!! on the C6K
jerry
Hi Dennis Ariel Leon Murillo,
I am also facing same issue , I am seeing (suspended(no lacp pdus)) on secondary N7K interface. Can you tell us if you able to solve this issue.
