VPC failed between 5548 and 2232
Pete89
Level 2
Level 2
This is my first stab at VPCs. Here is what we are working with for hardware:
2 5548s
2 2232s
Twinax for 5k to 5k VPC
FET-10g fro 2k to 5k VPC
HP Servers with dual port CNAs
And here is a drawing of the topology:
The 5k to 5k VPC looks good:
bottomSW# sh vpc br
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary
Number of vPCs configured       : 1
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     1,101
vPC status
id     Port        Status Consistency Reason                     Active vlans
10     Po10        down*  failed      Consistency Check Not      -
                                      Performed
But as you can see VPC 10 which is the 2k to 5k VPC is down.
When I do a show interface ethernet 100/1/1
I get this:
Ethernet100/1/1 is down (SFP not inserted)
Which is pretty interesting since I can mange the 2k from the 5k. Here is the whole config for one 5k:
bottomSW# sh run
!Command: show running-config
!Time: Wed Sep  7 17:46:29 2011
version 5.0(3)N2(1)
feature telnet
cfs eth distribute
feature interface-vlan
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
username admin password 5 $1$zrjRKCYM$rQilwKQUCG4t.HMK4nmd/1  role network-admin
no password strength-check
ip domain-lookup
hostname bottomSW
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
fex 100
  pinning max-links 1
  description "FEX0100"
snmp-server user admin network-admin auth md5 0x03400bbb1e9f6a9774fdd375c4d30349
priv 0x03400bbb1e9f6a9774fdd375c4d30349 localizedkey
vrf context management
  ip route 0.0.0.0/0 10.3.0.13
vpc domain 1
  peer-keepalive destination 10.3.0.13
interface Vlan1
  no shutdown
interface port-channel1
  switchport mode trunk
  vpc peer-link
  switchport trunk allowed vlan 1,101
  spanning-tree port type network
interface port-channel10
  vpc 10
  switchport access vlan 101
interface port-channel100
  switchport mode fex-fabric
  fex associate 100
interface Ethernet1/15
  fex associate 100
  channel-group 100
interface Ethernet1/16
  description VPC peer link
  channel-group 1 mode active
interface Ethernet1/31
  fex associate 100
  channel-group 100
interface Ethernet1/32
interface mgmt0
  description keep alive to topSW
  ip address 10.3.0.12/27
interface Ethernet100/1/1
  channel-group 10
interface Ethernet100/1/2
  channel-group 10
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.3.N2.1.bin
boot system bootflash:/n5000-uk9.5.0.3.N2.1.bin
bottomSW#
Thanks for any advice or help!!!
P.
9 Replies 9
Jerry Ye
Where is the server connected to on the FEX?
I am seeing you did a port-channel on the same FEX
  vpc 10
  channel-group 10
  channel-group 10
Your server has 4 ethernet interfaces? 2 to N5K-1 and 2 to N5K-2? Can you show the other switch's configuration?
jerry
Hi Jerry,
There are no servers attached yet to the 2ks. All I am trying to do now are the VPCs between the 5k and the 2ks. In the drawing the red circles represent the VPCs.
So, in my case I am trying to create a VPC with two member interfaces on the 2k to one upstream 5k
If you do two member interfaces on a N2K to one upstream N5K, it is not a vPC. It is a regular port-channel. vPC means port-channel touch both switches.
jerry
Ok, now I am confused. Arent the yellow labled ports on the right side of the 2232 the uplink ports that should go to the 5ks? Where do I configure them?
According from your topology, the FEX/N2K connection to the N5K is not a vPC. It is a regular port-channel.
The connection between to N5K to the 4507(?) is a vPC.
The cross link between (peer-link) is not a vPC.
The server connection to the FEX if they are attaching to both N2K, it is a vPC. If you are only attach to 1 FEX, it is a port-channel.
HTH,
jerry
OK I bought all this gear because Cisco told me that I could get VPCs and get rid of STP. Now I am back to using port channels again? I showed this drawing to a data center designer. I asked him everywhere you see a red circle is a VPC right? I was told yes by him.
So let me ask again. In my drawing the only VPC is down where the CNAs and 2ks meet? Everything else has to be port channel?
The devil is in the details for sure.
Thank you,
P.
First of all, port-channel (802.1ad) is not spanning-tree (802.1w - rapid spanning-tree), port-channel is bundling multiple physical interfaces into 1 logical interface.
Yes the only vPCs are the servers connected to two different N2Ks.
The only explaination I can give you is, you have to set up a vPC domain in both N5K. Maybe this is why he said it is a vPC(???).
jerry
OK Jerry,
I enjoyed the crash course in vPC and port channel. I believe you are right, I think I confused the use of the terms vPC domain and vPC at the port level.
I found this which helps out , bui it never explains that the uplink ports on the 2ks have no configuration on thier own. The ports on the 5k that go to 2ks get:
  fex associate number
  channel-group number
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
I appreciate the time you took to explain!!
P.
Here is another example you can take a look (Basic Configuration - No Port Profile):
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_config_sync_ops.html#wp1080810
You have to do the same configuration on both N5Ks.
jerry
