VPC NEXUS 5k 2K
karimbruxelles
I have got two pairs of NEXUS switches 5k and 2k
The two 5 k are connected through 4 connections (port-channel) but it doesn't seems to work??
The idea is to setup a server with a double path connected to n2k ->  5k and create a VPC between the two differents switches on access mode
N11-BKP# show port-channel summary
1     Po1(SU)     Eth      LACP      Eth1/1(P)    Eth1/2(P)    Eth1/3(P)
                                     Eth1/4(P)
2     Po2(SD)     Eth      LACP      Eth1/5(s)    Eth1/6(D)
N11-BKP# show running-config interface port-channel 1
interface port-channel1
  description Inter-Link N11-N12
  switchport mode trunk
  switchport trunk allowed vlan 1-776,778-3967,4048-4093
  vpc peer-link
  spanning-tree port type network
N11-BKP# show vpc 1
vPC status
id     Port        Status Consistency Reason                     Active vlans
N11-BKP#
N11-BKP# show vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 1
Peer status                     : peer link is down
                                  (vPC peer is not reachable over
                                  cfs)
vPC keep-alive status           : peer is alive
Configuration consistency status: failed
Per-vlan consistency status     : success
Configuration consistency reason: Consistency Check Not Performed
Type-2 consistency reason       : Consistency Check Not Performed
vPC role                        : none established
Number of vPCs configured       : 2
Peer Gateway                    : Enabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Disabled (due to peer configuration)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     -
vPC status
2      Po2         down   failed      Consistency Check Not      -
                                      Performed
15     Po15        down   failed      Consistency Check Not      -
                                      Performed
N11-BKP# show vpc 2
vPC status
                                      Performed
N11-BKP# show vpc consistency-parameters vpc 1
N11-BKP# show vpc consistency-parameters vpc 2
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
Shut Lan                    1     No                     -
STP Port Type               1     Default                -
STP Port Guard              1     None                   -
STP MST Simulate PVST       1     Default                -
Allowed VLANs               -     1-776,778-3967,4048-40 -
                                  93
Local suspended VLANs       -     -                      -
N11-BKP#
I don't have a clue of what is happening
Reza Sharifi
You do not have domain id in your config:
example:
switch(config)# vpc domain 5
have a look at this doc for more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
No I do have a domain 1 (on all of my switches) but I found the answer actually on the links between the two nexus
the vpc peer-link was missing
vpc domain 1
  role priority 1
  peer-keepalive destination 192.168.254.208
  peer-gateway
