VPC peer-link between Nexus 5010 and 5020
chun.zhang
I'm trying to create a vpc between a Nexus 5010 and Nexus 5020 switch. I recently upgraded the software so they are running the same version. However, I connect get a vpc link. Is there something wrong with my setup? Is a vpc between a 5010 and 5020 even possible? They are connected using a pair of Intel X520's in 802.3AD teaming mode. Thanks in advance.
N5010N5020
!Command: show running-config vpc
!Time: Wed Aug  8 20:50:16 2012
version 5.2(1)N1(1)
feature vpc
vpc domain 1
  peer-keepalive destination 172.25.182.51
  auto-recovery
interface port-channel1
  vpc peer-link
!Time: Wed Aug  8 21:26:15 2012
version 5.2(1)N1(1)
feature vpc
vpc domain 1
  role priority 10000
  peer-keepalive destination 172.25.182.52
  auto-recovery
  vpc peer-link
N5010(config-if)# show vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer link is down
                                  (vPC peer is not reachable over
                                  cfs)
vPC keep-alive status             : peer is alive
Configuration consistency status  : failed
Per-vlan consistency status       : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason       : Consistency Check Not Performed
vPC role                          : none established
Number of vPCs configured         : 0
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Disabled (due to peer configuration)
Auto-recovery status              : Enabled (timeout = 240 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    down   -
N5020# show vpc
Legend:
vPC domain id                     : 1
                                  cfs)
1    Po1    up     -
N5010(config-if)# show cfs status
Distribution : Enabled
Distribution over IP : Enabled - mode IPv4
IPv4 multicast address : 239.255.70.83
IPv6 multicast address : ff15::efff:4653
Distribution over Ethernet : Enabled
N5020# show cfs status
!Command: show running-config interface port-channel1
!Time: Wed Aug  8 20:52:13 2012
version 5.2(1)N1(1)
  switchport mode trunk
  switchport trunk allowed vlan 1-14
  spanning-tree port type network
  speed 10000
  vpc peer-link
!Time: Wed Aug  8 21:29:19 2012
version 5.2(1)N1(1)
  speed 10000
  vpc peer-link
Reza Sharifi
Can you add this command to both devices:
peer-keepalive destination 172.25.182.51 source 172.25.182.52 vrf management
peer-keepalive destination 172.25.182.52 source 172.25.182.51 vrf management
Also do you have a portchannel configured?
Have a look at this link for config example:
http://nexusfu.blogspot.com/2012/01/enhanced-vpc.html
Reza Sharifi
Thanks for the reply. I took down my existing vpc configuration (no'ed everything) and I went to the nexusfu url and followed the steps identically (except ip addresses) up until the show vpc. However, this is what I get on both switches (below). It indicates that the peer link is down, but the peer is alive?
Edit:
Nevermind! I had to do a write-erase and reload of one of the switches due to a policy map issue (probably left over from when I ugpraded the switch software. Everything works now.
