VPC Question
john-cabrera
Community Member
I have 2 5548's and I set them up with VPC Peer-Links (port-Channel 101). Its up and running.  As a test, I configured a 3560 for VPC (port channel 9).  However, only vlan 10 is active.  Do I need to add all the vlans in port-channel 101? Here is my config
interface port-channel9
  switchport mode trunk
  spanning-tree port type network
  speed 1000
  vpc 9
interface Ethernet1/9
  speed 1000
  channel-group 9 mode active
interface port-channel101
  description Connect-other-5548
  switchport trunk allowed vlan 10,101
  speed 10000
  vpc peer-link
interface Ethernet1/32
  description VPC Connection to other 5548
  channel-group 101 mode active
VPC Peer-link status
id   Port   Status Active vlans
1    Po101  up     10
vPC status
id     Port        Status Consistency Reason                     Active vlans
9      Po9         up     success     success                    10
In port channel 9 all vlans will be active by default, but port channel you have only 10 and 101, is 101 an active vlan?  are there any other vlans that should be active. perhaps you need "switchport trunk allowed vlan all" on port channel 101
Richard.
Ganesh Hariharan
Hello John,
The peer-link PortChannel connects vPC peers and carries all access VLANs (defined by the user). This link also carries additional traffic that the user does not need to define: more specifically, BPDUs and HSRP hellos and MAC address synchronization between the vPC peers.
It is a special link for carrying L2 traffic between the VPC peer switches when there is a link failure.
This link is by far the most important component of the vPC system. Although its failure does not disrupt existing vPC flows, its failure can impair the establishment of new flows and isolate orphan ports.
So add what are access vlan you are running on those switches to make peer link effective.
Hope it Helps..
-GI
Rate if it Helpss
No, you should not do that.
Any non-vPC VLANs should be not allowed on the vPC peer-link trunk.
Please check the links below for sample configuration and check list.
http://www.netcraftsmen.com/port-channels-vpcs-and-spanning-tree-issues
http://docwiki.cisco.com/wiki/Cisco_Nexus_7000_Series_NX-OS_Troubleshooting_Guide_--_Troubleshooting_vPCs
Hope it helps,
Masoud
