vPC system-mac issue
Saeedullah Khan
I am going to configure vPC on nexus 5548 model and initially, i have successfully configured the keepalive and pinging but when checking the command.
N5k-Primary(config)# feature vpc
N5k-Primary(config)# vpc domain 1
N5k-Primary(config-vpc-domain)# show vpc role
vPC Role status
vPC role : none established
Dual Active Detection Status : 0
vPC system-mac : 00:00:00:00:00:00
vPC system-priority : 32667
vPC local system-mac : 00:2a:6a:8f:78:81
vPC local role-priority : 0
NK-Primary(config-vpc-domain)#
My concern about vPC system-mac which is nothing showing.
What should i do? should i follow the next commands and then check?
Waiting for quick reply.
6 Replies 6
vPC system-mac : 00:00:00:00:00:00 <<- this used by both NSK so it appear after vPC success
show vpc brief <<- I need to see this
Listen, i have not yet successfully configured the others vpc commands but here is the output.
NK-Primary# sh vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer link not configured
vPC keep-alive status : Disabled
Configuration consistency status: failed
Per-vlan consistency status : failed
Configuration consistency reason: vPC peer-link does not exist
Type-2 consistency status : failed
Type-2 consistency reason : vPC peer-link does not exist
Number of vPCs configured : 0
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
NK-Primary#
peer-link not config and keep-alive is disabled
sure that why the mac address of vPC is not appear
vPC system-mac : 00:00:00:00:00:00 <-this MAC use by both NSK it shared and it appear when vPC success
vPC local system-mac : 00:2a:6a:8f:78:81 <- this MAC address of NSK
so there is no problem only complete the config and this MAC address will appear automatic after vPC is success
after vPC is success the mac appear, so no problem at all, only complete the config
config peer-link
keep-alive
 It should be created automatically but you can also put a mac address there by using the command
   system-mac < MAC >  inside vPC domain
https://www.dclessons.com/vpc-configuration-best-practices
I have configured the mac manually but cant see the result. i have noticed one thing about the versions which is not identical. please correct me is this the issue?
vPC local system-mac : 54:7f:ee:bf:7a:81
Hardware
cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
Intel(R) Xeon(R) CPU with 8299528 kB of memory.
Processor Board ID FOC17475V6W
Device name: NK-Primary
bootflash: 2007040 kB
Kernel uptime is 0 day(s), 2 hour(s), 4 minute(s), 12 second(s)
Last reset at 940670 usecs after Wed May 24 12:34:36 2017
Reason: Reset Requested by CLI command reload
System version: 5.0(3)N2(1)
Hardware
cisco Nexus5548 Chassis ("O2 32X10GE/Modular Supervisor")
Intel(R) Xeon(R) CPU with 8263880 kB of memory.
Processor Board ID FOC16292FRW
Device name: NK-Secondary
Kernel uptime is 0 day(s), 2 hour(s), 4 minute(s), 0 second(s)
Last reset at 81719 usecs after Mon Sep 30 08:09:10 2019
System version: 5.1(3)N1(1a)
Service:
