VPC with HSRP and Intervlan Routing Design
Sajid Khan
We two nexus switch 9k and configured with VPC and HSRP, we have configured three vlan on that three switches. Vlan 2 for CCTV , vlan 3 for Monitering PC and vlan 1 for Dell Server that connected with two 9k switches by port channel.  The two nexus switches is also connected two one distribution switch by port channel. when i do not know how , these two 9k switches are active / active in hsrp when i shutdown one uplink Eth1/2 of 9k1 which is active  then traffic do not move on 9k2. let me correct if my design is okay.
9K1 Configuration ------------
config t
hostname 9K1-SW1
vlan 1
name DellRecordingServer
exit
vlan 2
name CCTV
exit
vlan 3
name MonitoringPC
exit
feature vpc
feature lacp
feature interface-vlan
int vlan 1
ip add 1.1.1.1 255.255.255.0
no shut
int vlan 2
ip add 192.168.2.1 255.255.255.0
no shut
int vlan 3
ip add 192.168.3.1 255.255.255.0
no shut
exit
vrf context VPC-KEEPALIVE
interface Ethernet 1/51
no shutdown
no switchport
vrf member VPC-KEEPALIVE
ip address 50.50.50.1 255.255.255.0
exit
interface Ethernet 1/49, Ethernet 1/50
no shut
switchport mode trunk
switchport trunk allowed vlan 1-3
description **VPC-PEERLINK**
channel-group 100 mode active
no shutdown
vpc domain 50
peer-gateway
role priority 20
peer-keepalive destination 50.50.50.2 source 50.50.50.1 vrf VPC-KEEPALIVE
exit
interface port-channel 100
no shutdown
switchport
spanning-tree port type network
vpc peer-link
exit
interface Ethernet 1/2
no shutdown
channel-group 2 mode on
interface port-channel 2
no shutdown
vpc 2
exit
interface eth 1/1
no shutdown
channel-group 1 mode on
description *** Po1 to Server-1 ***
switchport
switchport mode access
switchport access vlan 1
vpc 1
exit
feature hsrp
interface Vlan 1
no shutdown
hsrp 1
ip 1.1.1.254
priority 200
preempt
exit
interface Vlan 2
no shutdown
hsrp 2
ip 192.168.2.254
priority 200
preempt
exit
interface Vlan 3
no shutdown
hsrp 3
ip 192.168.3.254
priority 200
preempt
exit
9K2 Configuration ------------
config t
hostname 9K2-SW2
vlan 1
exit
vlan 2
name CCTV
exit
vlan 3
name MonitoringPC
exit
feature vpc
feature lacp
int vlan 1
ip add 1.1.1.2 255.255.255.0
no shut
int vlan 2
ip add 192.168.2.2 255.255.255.0
no shut
int vlan 3
ip add 192.168.3.2 255.255.255.0
no shut
exit
no shutdown
no switchport
ip address 50.50.50.2 255.255.255.0
exit
no shutdown
vpc domain 50
peer-gateway
role priority 40
peer-keepalive destination 50.50.50.1 source 50.50.50.2 vrf VPC-KEEPALIVE
exit
no shutdown
switchport
vpc peer-link
exit
no shutdown
no shutdown
vpc 2
exit
interface eth 1/1
no shutdown
switchport
vpc 1
exit
feature hsrp
interface Vlan 1
no shutdown
hsrp 1
ip 1.1.1.254
priority 150
preempt
exit
interface Vlan 2
no shutdown
hsrp 2
ip 192.168.2.254
priority 150
preempt
exit
interface Vlan 3
no shutdown
hsrp 3
ip 192.168.3.254
priority 150
preempt
exit
Distribution switch configuration .....................
config t
hostname DistSW
vlan 1
exit
vlan 2
name CCTV
exit
vlan 3
name MonitoringPC
exit
interface range ethernet 0/0-1
no shutdown
exit
32 Replies 32
I am 100 % sure that i assigned gateway to Host/server as VIP not ip of vlan svi of nsk1 or nsk2. i assigned gateway ip as vip in host/server.
i am testing this in EVNG environment not in physical.
Sajid Khan
This design is correct.
Sajid Khan
No one can reply to me?
just give us time,
NOW
share
show route and show ip interface brief <<- after the Link is down
same time share spanning tree in case of Link UP and Link Down, what is STP mode you use ?
still wait
show route
show spanning tree
9K1-SW1# show ip route
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
1.1.1.0/24, ubest/mbest: 1/0, attached
*via 1.1.1.1, Vlan1, [0/0], 00:22:22, direct
1.1.1.1/32, ubest/mbest: 1/0, attached
*via 1.1.1.1, Vlan1, [0/0], 00:22:22, local
1.1.1.254/32, ubest/mbest: 1/0, attached
*via 1.1.1.254, Vlan1, [0/0], 00:21:35, hsrp
192.168.2.0/24, ubest/mbest: 1/0, attached
*via 192.168.2.1, Vlan2, [0/0], 00:20:42, direct
192.168.2.1/32, ubest/mbest: 1/0, attached
*via 192.168.2.1, Vlan2, [0/0], 00:20:42, local
192.168.2.254/32, ubest/mbest: 1/0, attached
*via 192.168.2.254, Vlan2, [0/0], 00:20:21, hsrp
192.168.3.0/24, ubest/mbest: 1/0, attached
*via 192.168.3.1, Vlan3, [0/0], 00:20:42, direct
192.168.3.1/32, ubest/mbest: 1/0, attached
*via 192.168.3.1, Vlan3, [0/0], 00:20:42, local
192.168.3.254/32, ubest/mbest: 1/0, attached
*via 192.168.3.254, Vlan3, [0/0], 00:20:21, hsrp
9K1-SW1# show ip interface brief
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan1 1.1.1.1 protocol-up/link-up/admin-up
Vlan2 192.168.2.1 protocol-up/link-up/admin-up
Vlan3 192.168.3.1 protocol-up/link-up/admin-up
9K1-SW1# show spanning-tree
VLAN0001
Spanning tree enabled protocol rstp
Root ID Priority 32769
Address 5000.0001.0007
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 1 128.4096 (vPC) P2p
Po2 Desg FWD 1 128.4097 (vPC) P2p Peer(STP)
Po100 Desg FWD 3 128.4195 (vPC peer-link) Network P2p
Eth1/3 Desg FWD 4 128.3 P2p
Eth1/4 Desg FWD 4 128.4 P2p
Eth1/5 Desg FWD 4 128.5 P2p
Eth1/6 Desg FWD 4 128.6 P2p
Eth1/7 Desg FWD 4 128.7 P2p
Eth1/8 Desg FWD 4 128.8 P2p
Eth1/9 Desg FWD 4 128.9 P2p
Eth1/10 Desg FWD 4 128.10 P2p
Eth1/11 Desg FWD 4 128.11 P2p
Eth1/12 Desg FWD 4 128.12 P2p
Eth1/13 Desg FWD 4 128.13 P2p
Eth1/14 Desg FWD 4 128.14 P2p
Eth1/15 Desg FWD 4 128.15 P2p
Eth1/16 Desg FWD 4 128.16 P2p
Eth1/17 Desg FWD 4 128.17 P2p
Eth1/18 Desg FWD 4 128.18 P2p
Eth1/19 Desg FWD 4 128.19 P2p
Eth1/20 Desg FWD 4 128.20 P2p
Eth1/21 Desg FWD 4 128.21 P2p
Eth1/22 Desg FWD 4 128.22 P2p
Eth1/23 Desg FWD 4 128.23 P2p
Eth1/24 Desg FWD 4 128.24 P2p
Eth1/25 Desg FWD 4 128.25 P2p
Eth1/26 Desg FWD 4 128.26 P2p
Eth1/27 Desg FWD 4 128.27 P2p
Eth1/28 Desg FWD 4 128.28 P2p
Eth1/29 Desg FWD 4 128.29 P2p
Eth1/30 Desg FWD 4 128.30 P2p
Eth1/31 Desg FWD 4 128.31 P2p
Eth1/32 Desg FWD 4 128.32 P2p
Eth1/33 Desg FWD 4 128.33 P2p
Eth1/34 Desg FWD 4 128.34 P2p
Eth1/35 Desg FWD 4 128.35 P2p
Eth1/36 Desg FWD 4 128.36 P2p
Eth1/37 Desg FWD 4 128.37 P2p
Eth1/38 Desg FWD 4 128.38 P2p
Eth1/39 Desg FWD 4 128.39 P2p
Eth1/40 Desg FWD 4 128.40 P2p
Eth1/41 Desg FWD 4 128.41 P2p
Eth1/42 Desg FWD 4 128.42 P2p
Eth1/43 Desg FWD 4 128.43 P2p
Eth1/44 Desg FWD 4 128.44 P2p
Eth1/45 Desg FWD 4 128.45 P2p
Eth1/46 Desg FWD 4 128.46 P2p
Eth1/47 Desg FWD 4 128.47 P2p
Eth1/48 Desg FWD 4 128.48 P2p
VLAN0002
Root ID Priority 32770
Bridge ID Priority 32770 (priority 32768 sys-id-ext 2)
VLAN0003
Root ID Priority 32771
Bridge ID Priority 32771 (priority 32768 sys-id-ext 3)
9K2-SW2# sh ip int
interface internal
9K2-SW2# sh ip interface brief
Vlan1 1.1.1.2 protocol-up/link-up/admin-up
Vlan2 192.168.2.2 protocol-up/link-up/admin-up
Vlan3 192.168.3.2 protocol-up/link-up/admin-up
9K2-SW2#
9K2-SW2# show spanning-tree
VLAN0001
Cost 3
Port 4195 (port-channel100)
Address 5000.0002.0007
Po100 Root FWD 3 128.4195 (vPC peer-link) Network P2p
VLAN0002
Cost 3
VLAN0003
Cost 3
9K2-SW2# sh ip route
*via 1.1.1.2, Vlan1, [0/0], 00:26:54, direct
1.1.1.2/32, ubest/mbest: 1/0, attached
*via 1.1.1.2, Vlan1, [0/0], 00:26:54, local
*via 1.1.1.254, Vlan1, [0/0], 00:26:07, hsrp
*via 192.168.2.2, Vlan2, [0/0], 00:26:20, direct
192.168.2.2/32, ubest/mbest: 1/0, attached
*via 192.168.2.2, Vlan2, [0/0], 00:26:20, local
*via 192.168.2.254, Vlan2, [0/0], 00:25:38, hsrp
*via 192.168.3.2, Vlan3, [0/0], 00:26:20, direct
192.168.3.2/32, ubest/mbest: 1/0, attached
*via 192.168.3.2, Vlan3, [0/0], 00:26:20, local
*via 192.168.3.254, Vlan3, [0/0], 00:25:38, hsrp
if i shutdown one link E1/2 of NK1 then ping will continue success, no drop  but once i no shutdown that E1/2 of Nk1 then traffic will drop. kindly review with picutre
9K1-SW1#show ip interface brief
VLAN0001
VLAN0002
VLAN0003
this OK,
show port-channel in three SW (two NSK and one other SW) when link is UP and Down,
NOTE:- you use RSTP as MODE ? if Yes and it Lab change the config to be PVST
this lab for you
to see we care and read all your post but time is limit,
anyway the issue I face and make me late reply is RAM of my PC I can not use four NSK in one LAB
I use three and two PO on for VLAN10 and other for VLAN20
shut down one link of PO for VLAN10 and you see the ping still success.
point I mention above can be critical
the SVI of NSK down automatic in case the peer-link down not on one of PO member down
1 :can you ping -t and then shut down on link for PO for VLAN 10 and then no shutdown same link and then check ping.
Sure i will try and share reuslt here
Server IP
GW:VIP
