VRF IPv6 address-family is not supported
keiththomas
I recently received a C1921 and am doing some lab testing. I am trying to apply some old configs from a 2811 but some commands are not working.
The most annoying to start is the ipv6 address family in a vrf definition (multi-vrf/VRF-lite). There is no option, it only provides ipv4.
C1921-TopRight(config)#vrf definition test1
C1921-TopRight(config-vrf)#address-family ?
  ipv4  Address family
Why no IPv6?. I have IPv6 unicast routing enabled and can apply addresses to interfaces on the global vrf. If I try to apply an IPv6 address to an interface in the vrf test1, it complians that IPv6 is not enabled for that vrf, yet I can't enable it in the vrf.
Some posts with similar problems were on 7200s and the solution was to use the command 'mls ipv6 vrf' but that command does not apply to this router.
Any ideas? Is there some caveat in the licensing?
Below is my 'show version' and 'show license'
C1921-TopRight#sho ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 13:55 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
C1921-TopRight uptime is 21 hours, 11 minutes
System returned to ROM by reload at 01:26:21 UTC Thu May 19 2011
System image file is "flash:c1900-universalk9-mz.SPA.151-4.M.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL151522R2
2 Gigabit Ethernet interfaces
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FGL151522R2
Technology Package License Information for Module:'c1900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
data          None          None          None
C1921-TopRight#sho lice
C1921-TopRight#sho license de
C1921-TopRight#sho license detail ?
  WORD  Feature name to detail
  |     Output modifiers
  <cr>
Index: 1        Feature: SSL_VPN                           Version: 1.0
        License Type: Evaluation
        License State: Not in Use, EULA not accepted
            Evaluation total period: 208 weeks 2  days
            Evaluation period left: 208 weeks 2  days
        License Count: 5000/0/0  (Active/In-use/Violation)
        License Priority: None
        Store Index: 8
        Store Name: Evaluation License Storage
Index: 2        Feature: SSL_VPN                           Version: 1.0
        License State: Inactive
        Store Index: 7
Index: 3        Feature: SSL_VPN                           Version: 1.0
        Store Index: 6
Index: 4        Feature: WAAS_Express                      Version: 1.0
        License Count: Non-Counted
        Store Index: 14
Index: 5        Feature: WAAS_Express                      Version: 1.0
        Store Index: 13
Index: 6        Feature: WAAS_Express                      Version: 1.0
        Store Index: 12
Index: 7        Feature: datak9                            Version: 1.0
        Store Index: 5
Index: 8        Feature: datak9                            Version: 1.0
        Store Index: 4
Index: 9        Feature: datak9                            Version: 1.0
        Store Index: 3
Index: 10       Feature: ios-ips-update                    Version: 1.0
        Start Date:         N/A, End Date: Dec 31 2025
        Store Index: 11
Index: 11       Feature: ios-ips-update                    Version: 1.0
        Store Index: 10
Index: 12       Feature: ios-ips-update                    Version: 1.0
        Store Index: 9
Index: 13       Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        Store Index: 0
        Store Name: Primary License Storage
Index: 14       Feature: securityk9                        Version: 1.0
        Store Index: 1
Index: 15       Feature: securityk9                        Version: 1.0
        Store Index: 2
Index: 16       Feature: securityk9                        Version: 1.0
        Store Index: 1
Index: 17       Feature: securityk9                        Version: 1.0
        Store Index: 0
keiththomas
Question withdrawn. Found the FAQ.
Certainly an odd little licensing quirk.
Reminds me of my cable company and their program packages.
