VRF-Lite, Route Leaking, ACL to control traffic between VRFs
Recently we implemented VRF-Lite I our struture.
In that job we also implemented RouteLeaking Between Coustumer VRFs, and our VRF(where we provide some services as Backup, Monitoring, NFS/iSCSI), etc, etc, etc...
We control those route-leaking with route-maps(there are many examples in this forum).
It is working fine, and does no consume so much resource of our cores as we were expecting.
But what we would like to do is to filter the traffic passing from one VRF to another VRF.
Lets imagine that those VRF would be different phisical routers.
Wolud exist common interface between then.
And wolud be possible to aply ACLs on those Interfaces.
What we want to do is something like that, but inside the same router, between the VRFs.
I tried to search some solution to that(google, cisco, supportforum), but I think that I'm not using the correct terms on the search.
I was looking the possible commands related to that and a found:
Possibility A
  • This is the VRF of our costumer, and my undestanding of that command is that any traffic leaked via from this VRF via BGP would be sourced from an specific loopback and there we would aply the ACLs that we  need. Am I right?
core-siteA(config)#ip vrf costumer-a
core-siteA(config-vrf)#?
VPN Routing/Forwarding instance configuration commands:
  bgp              Commands pertaining to BGP
  default          Set a command to its defaults
  description      VRF specific description
  exit             Exit from VRF configuration mode
  export           VRF export
  import           VRF import
  inter-as-hybrid  Inter AS hybrid mode
  maximum          Set a limit
  mdt              Backbone Multicast Distribution Tree
  no               Negate a command or set its defaults
  protection       Configure local repair
  rd               Specify Route Distinguisher
  route-target     Specify Target VPN Extended Communities
  snmp             Modify snmp parameters
  vpn              Configure VPN ID as specified in rfc2685
core-siteA(config-vrf)#bgp ?
  next-hop  Next-hop for the routes of a VRF in the backbone
core-siteA(config-vrf)#bgp next-hop ?
  Loopback  Loopback interface
core-siteA(config-vrf)#bgp next-hop loopback ?
  <0-2147483647>  Loopback interface number
core-siteA(config-vrf)#bgp next-hop loopback 0 ?
  <cr>
Possibility B
  • This would be the route-map used on reoute leaking, and the Idea  in this case is force the traffic that goes to our-company VRF to pass  for an specific Loopback and there we would aply the ACLs that we need. But my doubt is if this SET can be used on a route-leaking route-map !?!
core-siteA(config)#route-map VRF_COSTUMER-A_TO_OUR-COMPANY permit 10
core-siteA(config-route-map)#set ?
  as-path           Prepend string for a BGP AS-path attribute
  automatic-tag     Automatically compute TAG value
  clns              OSI summary address
  comm-list         set BGP community list (for deletion)
  community         BGP community attribute
  dampening         Set BGP route flap dampening parameters
  default           Set default information
  extcomm-list      Set BGP/VPN extended community list (for deletion)
  extcommunity      BGP extended community attribute
  global            Set to global routing table
  interface         Output interface
  ip                IP specific information
  ipv6              IPv6 specific information
  level             Where to import route
  local-preference  BGP local preference path attribute
  metric            Metric value for destination routing protocol
  metric-type       Type of metric for destination routing protocol
  mpls-label        Set MPLS label for prefix
  origin            BGP origin code
  tag               Tag value for destination routing protocol
  traffic-index     BGP traffic classification number for accounting
  vrf               Define VRF name
  weight            BGP weight for routing table
core-siteA(config-route-map)#set ip ?
  address     Specify IP address
  df          Set DF bit
  global      global routing table
  next-hop    Next hop address
  precedence  Set precedence field
  qos-group   Set QOS Group ID
  tos         Set type of service field
  vrf         VRF name
core-siteA(config-route-map)#set ip vrf ?
  WORD  VRF name
core-siteA(config-route-map)#set ip vrf our-company ?
core-siteA(config-route-map)#set ip vrf our-company next-hop ?
  A.B.C.D  IP address of next hop
core-siteA(config-route-map)#set ip vrf our-company next-hop 10.10.10.10 ?
  <cr>
Could any one make some correction or suggestion?
0 Replies 0
