VRF
andre.ortega
I want to create 15 subinterfaces in F0/0 and 15 subinterfaces in F0/1 and add each pair to a VFP.
EX:
F0/0.1 and F0/1.1 -> VRF1
F0/0.2 and F0/1.2 -> VRF2
F0/0.15 and F0/1.15 -> VRF15
Is it possible? What router support 15 VRFs?
cpubob
Level 6
Level 6
I just tried this on my Cisco 2600 and I stopped trying after I created 35 VRF's and added 35 subinterfaces, each belonging to 1 vrf.
I did get a warning message after the 15th vrf was created telling me that smartinit had been disabled and the system thinks thats a bad idea. I believe your only limited by memory at this point so if your low on memory, you won't be able to keep configuring vrf's but if you have a lot of free memory, you can configure a bunch.
Of course, I found Cisco's recommended numbers on this doc:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6557/prod_white_paper0900aecd8051fbdc.html
About 3/4 down the page is the "PERFORMANCE AND SCALABILITY" section. They only recommend 5 vrf's on a 2600XM.
Although it may be possible to configure 100 vrf's on the box and have everything working, you may run into a problem if you have to call TAC for support.
GL
-Rob
Giuseppe Larosa
Hello Andre,
15 VRFs are not a scalability issue you can use whatever router supports MPLS VPN.
I would try to understand if you want to have a real PE with MPLS forwarding capabilities or a device MultiVRF CE with a subset of features.
as a multiVRF CE you can also use a multilayer switch starting from c3550 with enterprise image
as PE router you can use different platforms depending on the aggregate traffic volume you want to support/expect for your VRFs.
Again you can use a multilayer switch like C6500 with SUP720 BXL or simply an ISR router like C2811 you want to build a lab or demo.
Hope to help
Giuseppe
cpubob
Level 6
Level 6
GL
-Rob
