VRRP interface tracking
mahesh18
Level 7
Level 7
Hi all,
I config 2691 as Master for VRRP and it was tracking int fa0/0.
I shutdown the interface fa0/0 and
2691 int fa1/1  was changed from master to backup.
2691Router#                      sh vrrp
FastEthernet1/1 - Group 30
  State is Backup
  Virtual IP address is 192.168.7.1
  Virtual MAC address is 0000.5e00.011e
  Advertisement interval is 0.100 sec
  Preemption enabled, delay min 60 secs
  Priority is 90
    Track object 1 state Down decrement 10
  Master Router is 192.168.7.2, priority is 100
  Master Advertisement interval is 1.000 sec
  Master Down interval is 0.909 sec (expires in 0.385 sec)
Then i checked the logs on the router which are below
Feb  9 11:42:58.652 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:42:58.688 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:02.124 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:02.188 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:03.100 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:03.116 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:05.812 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:05.836 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:07.636 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:07.668 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:08.580 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:08.616 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:09.528 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:09.588 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:10.500 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:10.576 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:14.169 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:14.213 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Feb  9 11:43:20.261 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Backup -> Master
Feb  9 11:43:20.273 MST: %VRRP-6-STATECHANGE: Fa1/1 Grp 30 state Master -> Backup
Need to know when int fa1/1 has become the backup then why it is bouncing between backup and master?
Mahesh
InayathUlla Sharieff
Hi Mahesh,
Can you please provide the configuration from both the switches?
Inayath
mahesh18
Level 7
Level 7
Hi Inayath
Here is config from both switches
R3#sh run int fa1/0
Building configuration...
Current configuration : 154 bytes
interface FastEthernet1/0
ip address 192.168.7.2 255.255.255.0
duplex auto
speed auto
vrrp 30 ip 192.168.7.1
vrrp 30 preempt delay minimum 60
end
R3#                     sh vrrp
FastEthernet1/0 - Group 30
  State is Backup
  Priority is 100
  Master Router is 192.168.7.3, priority is 100
  Master Down interval is 3.609 sec (expires in 3.529 sec)
2691Router#                                                   sh run int fastEthernet 1/1
Current configuration : 308 bytes
interface FastEthernet1/1
ip address 192.168.7.3 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
vrrp 30 timers advertise msec 100
vrrp 30 track 1
end
2691Router#                         sh vrrp
  State is Master
  Priority is 100
    Track object 1 state Up decrement 10
  Master Router is 192.168.7.3 (local), priority is 100
  Master Advertisement interval is 0.100 sec
Mahesh
Hi Mahesh,
I didnt find any issue on my device with this configuration.
Let me know how is your setup?
R u testing this on GNS? If yes do provide me the GNS file so that I test and get back to you with the result.
If its on live then provide me the network diagram and config from all the devices.
Inayath
