VRRP issue between Cisco and Juniper device
zizou6500
Hi Community,
I've made a VRRP setup between Cisco & Juniper device as below:
1/ On the Cisco devices:
- Two interfaces connected to the Juniper devices:
Gi1/1 (mode access )--> Junipr 1
GI1/2 (mode access ) --> Juniper2
The L3 config is under an SVI (the vlan id is being extended to the juniper devices).
2/ VRRP config on the Juniper device
The issue is that I can't ping the VRRP IP from the Cisco device. On the ARP table, I'm seeing only the real IP addresses of the Juniper devices.
Does anyone experience the above, I'm planning to change the configuration to trunk mode but I'm not sure that it will fix this issue.
I need your assistance here, thank you in advance!
Mark Elsen
                            - Check if these info-resources can be useful :
           https://blog.marquis.co/vrrp-between-cisco-and-juniper-switches/
           https://ultraconfig.com.au/blog/vrrp-configuration-between-a-cisco-ios-xe-and-junos-router/
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen,
Thank you for your help.
But in my case, there is no VRRP config on the Cisco device. It's only on the Juniper devices.
