IPSLA configuration
RRFS578780
Level 2
Level 2
I need to configure the IPSLA on the 9504, according to the procedure below, but the device does not have the IP SLA command
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/ip_sla/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x_chapter_0111.html
(config)# ip sla ?
% Invalid command at '^' marker.
(config)# ip sla
Hardware
cisco Nexus9000 C9504 (4 Slot) Chassis ("Supervisor Module")
# show license
# show feature
Feature Name Instance State
bash-shell 1 disabled
bfd 1 disabled
bgp 1 disabled
bulkstat 1 disabled
cable-management 1 disabled
catena 1 disabled
container-tracker 1 disabled
macsec 1 disabled
dhcp 1 enabled
dot1x 1 disabled
eigrp 1 enabled
eigrp 2 enabled(not-running)
eigrp 3 enabled(not-running)
eigrp 4 enabled(not-running)
eigrp 5 enabled(not-running)
eigrp 6 enabled(not-running)
eigrp 7 enabled(not-running)
eigrp 8 enabled(not-running)
eigrp 9 enabled(not-running)
eigrp 10 enabled(not-running)
eigrp 11 enabled(not-running)
eigrp 12 enabled(not-running)
eigrp 13 enabled(not-running)
eigrp 14 enabled(not-running)
eigrp 15 enabled(not-running)
eigrp 16 enabled(not-running)
eth-port-sec 1 disabled
evb 1 disabled
evc 1 disabled
evmed 1 disabled
fabric-access 1 disabled
grpc 1 disabled
hardware-telemetry 1 disabled
hmm 1 disabled
hsrp_engine 1 enabled
icam 1 disabled
imp 1 disabled
interface-vlan 1 enabled
isis 1 disabled
isis 2 disabled
isis 3 disabled
isis 4 disabled
isis 5 disabled
isis 6 disabled
isis 7 disabled
isis 8 disabled
isis 9 disabled
isis 10 disabled
isis 11 disabled
isis 12 disabled
isis 13 disabled
isis 14 disabled
isis 15 disabled
isis 16 disabled
itd 1 disabled
l2vpn 1 disabled
lacp 1 enabled
ldap 1 disabled
ldp 1 disabled
lldp 1 disabled
mpls-evpn 1 disabled
mpls_oam 1 disabled
mpls_static 1 disabled
msdp 1 disabled
mvrp 1 disabled
nat 1 disabled
nbm 1 disabled
netconf 1 disabled
ngmvpn 1 disabled
ngoam 1 disabled
npiv 1 disabled
nve 1 disabled
nxapi 1 disabled
nxsdk_app1 1 disabled
nxsdk_app10 1 disabled
nxsdk_app11 1 disabled
nxsdk_app12 1 disabled
nxsdk_app13 1 disabled
nxsdk_app14 1 disabled
nxsdk_app15 1 disabled
nxsdk_app16 1 disabled
nxsdk_app17 1 disabled
nxsdk_app18 1 disabled
nxsdk_app19 1 disabled
nxsdk_app2 1 disabled
nxsdk_app20 1 disabled
nxsdk_app21 1 disabled
nxsdk_app22 1 disabled
nxsdk_app23 1 disabled
nxsdk_app24 1 disabled
nxsdk_app25 1 disabled
nxsdk_app26 1 disabled
nxsdk_app27 1 disabled
nxsdk_app28 1 disabled
nxsdk_app29 1 disabled
nxsdk_app3 1 disabled
nxsdk_app30 1 disabled
nxsdk_app31 1 disabled
nxsdk_app32 1 disabled
nxsdk_app4 1 disabled
nxsdk_app5 1 disabled
nxsdk_app6 1 disabled
nxsdk_app7 1 disabled
nxsdk_app8 1 disabled
nxsdk_app9 1 disabled
nxsdk_mgr 1 disabled
onep 1 disabled
openflow 1 disabled
ospf 1 disabled
ospf 2 disabled
ospf 3 disabled
ospf 4 disabled
ospf 5 disabled
ospf 6 disabled
ospf 7 disabled
ospf 8 disabled
ospf 9 disabled
ospf 10 disabled
ospf 11 disabled
ospf 12 disabled
ospf 13 disabled
ospf 14 disabled
ospf 15 disabled
ospf 16 disabled
ospfv3 1 disabled
ospfv3 2 disabled
ospfv3 3 disabled
ospfv3 4 disabled
ospfv3 5 disabled
ospfv3 6 disabled
ospfv3 7 disabled
ospfv3 8 disabled
ospfv3 9 disabled
ospfv3 10 disabled
ospfv3 11 disabled
ospfv3 12 disabled
ospfv3 13 disabled
ospfv3 14 disabled
ospfv3 15 disabled
ospfv3 16 disabled
pbr 1 disabled
pim 1 disabled
pim6 1 disabled
plb 1 disabled
poe 1 disabled
private-vlan 1 disabled
privilege 1 disabled
ptp 1 disabled
restconf 1 disabled
rip 1 disabled
rip 2 disabled
rip 3 disabled
rip 4 disabled
rise 1 disabled
scheduler 1 disabled
scpServer 1 disabled
segment-routing 1 disabled
sflow 1 disabled
sftpServer 1 disabled
sla_responder 1 disabled
sla_sender 1 disabled
smart-channel 1 disabled
sshServer 1 enabled
tacacs 1 disabled
telnetServer 1 enabled
tunnel 1 disabled
udld 1 disabled
vmtracker 1 disabled
vni 1 disabled
vnseg_vlan 1 disabled
vpc 1 enabled
vrrp 1 disabled
vrrpv3 1 disabled
vtp 1 enabled
5 Replies 5
Georg Pauwen
what are your options at the feature level ?
N9504(config)#feature sla ?
(config)# feature sla ?
responder Enable/Disable responder part of SLA
sender Enable/Disable sender part of SLA
As George already indicated, you need to enable first the SLA feature. This is how NXOS works - to access the CLI of any feature (ospf, pim, sla etc) you need to enable the feature first. In your case, the feature is disabled:
You need to enable it using:
conf t
feature sla sender
Stay safe,
Sergiu
Do I need financial resources to enable this feature?
no. If the feature is available, it is included in the license you have currently installed.
