05-06-2010 11:17 AM - edited 03-06-2019 10:58 AM
One Question...
Do i really need to use a port channel for my vsl link ?
can i just take one TenGig interface on each supervisor
and put the virtual switch link ... command on each interface
... without creating the Port-Channel ?
thanks
05-06-2010 11:22 AM
desrochj1 wrote:
One Question...
thanks
You can use a single link but VSS is designed to be a highly available system so using a single link is introducing a single point of failure into the system.
Jon
05-06-2010 11:56 PM
One Question...
thanks
It's always a better recommendation to have vsl link with port channel configuration, check out the below link for more information
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml#vss_best
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
