VSS Best practices
marhifer2003
Cisco recommends not to use "mode on" on MECs. why?
Recommendations
* Always run L2 or L3 MEC.
* Do not use on and off options with PAgP or LACP or Trunk
protocol negotiation.
o PAgP — Run Desirable-Desirable with MEC links.
o LACP — Run Active-Active with MEC links.
o Trunk — Run Desirable-Desirable with MEC links.
Thanks in advance-
krahmani323
Level 3
Level 3
Hello Marhifer,
From the VSS Cisco validated design guide (CVD) regarding the MEC configuration mode
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_ch2.html#wp1056543 (In Modes of PAgP Operation section).
Out of the three choices shown, the recommended mode for PAgP neighbors is desirable-desirable. This configuration option enables PAgP on both sides and forces the consistency check mentioned previously in this section. The desirable-desirable option is the best option for ensuring safe and reliable operation of MEC-connected devices.
LACP Mode of Operation
For the same reasons described in preceding PAgP description, table 2-5 shows only the best practice-based configuration options. Our of the three choices shown, the recommended mode for LACP neighbors is active-active
On the other hand, the configuration of the Etherchannel mode for the VSL link must be set to on.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_ch2.html#wp1056015
Since VSL EtherChannel uses LMP per member link, the link-aggregation protocols, such as PAgP and LACP, are not required; each member link must be configured in unconditional EtherChannel mode using the channel-group group-number mode on command.
Hope that helps.
Thanks and regards
Karim
Thank you krahmani323
Using "mode on" could cause any problem? we are experiencing some traffic losses intermitently.
Thanks in advance
