11-10-2014 06:09 AM - edited 03-07-2019 09:27 PM
I am currently constructing a network design and plan to use VSS, I am quite new to VSS and so far I have only read about it. Thus before including it in my project plan I would like to conduct a test/lab between a 3750 & a 3750x but am not sure if having a different model switch would allow the VSS to form?
In the actual implementation I plan to use two stand along 3750x but I would first like to see if it works in my lab. If having a different model switch is not doable I will get another 3750 just to be sure...
Thanks in advance
Angelic :)
Solved! Go to Solution.
11-10-2014 07:04 AM
11-10-2014 06:37 AM
VSS not supported on 3750 or 3750X.
11-10-2014 06:52 AM
So it is only supported on the 6500 series? I was told that it was also supported on the 3750x...
11-10-2014 07:04 AM
Not supported on 3750 series.
Works on the 4500x and 6500.
11-10-2014 07:07 AM
Understood, Thanks...
