VSS in C6880-X
mohammad saeed
Level 5
Level 5
Hi guys,
I was reading about C6880-X and found that can work with VSS technology. but how without sup2t modules! like 6708-XL! because in CCW I just found one type of line cards compatible is 10G line card!
I want to understand how can I use it for VSS between two C6880-X!
Mhammad
Based on your concern I meant that VSS will works on 6880x.
Now on 6000 series, VSS should be mounted only over 10G links. If I remember correctly, all the 16 embedded ports are 1G/10G based on SFP or SFP+. Then yes, if you connect SFP+ you will be able to create a VSL link and build a VSS cluster.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
Your question is why c6880 switches can be setup as a VSS cluster?
This is a small form factor chassis and it has an embedded supervisor that works in the same architecture as a Sup2T. Take a look on the datasheet right here: http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6880-x-switch/data_sheet_c78-728228.html
Then Yes, you can setup your 2 boxes in a VSS cluster.
Hope I've answered to your question
Francesco
Hi Francesco!
you mean I can use SFP in the fixed chassis to work as VSS instead of two 10 gig ports like 6807 chassis!
thanks
Francesco
Now I got it! so it should be 10G  for VSS!
Yes 10G for 6k switches. On 4k switches you can build a VSS with 1G links.
On your 6880x, you have 10G ports already then you can go with VSS.
Francesco
