01-30-2012 06:20 PM - edited 03-07-2019 04:38 AM
Hello, We are planning to move to quad sup setup and from the documentation it seems straight forward.
But I couldn't find any specifics on compatibility of Supervisor modules. May I know if the hw/fw version of sup matters?
I have below sups with same IOS but different hw/fw. Are they compatible t use as ICA/ICS and VSS active/Hot-standby?
Sup 1
hw:- 3.2 fw:- 8.5(4)
Sup 2
hw:- 3.1 fw:- 8.5(3)
Thank you.
01-30-2012 06:47 PM
For VSS, you have to have Sup-720-VS or Sup-2T. VSS is not possible with Sup-1 Sup-2, Sup-32.
01-30-2012 08:05 PM
Hi Reza, we have already running VSS setup with dual Sup VS-S720-10G. The aboe hw/fw versions are from current running VSS environment.
Thank you.
