09-02-2015 10:51 PM - edited 03-08-2019 01:37 AM
Hi all,
I am using 2 cisco C6807-XL as a VSS switch.Switch1 is the active switch and Switch2 is the standby.The issue is when I switchoff the active switch(Switch1) the switch2 becomes active but after switch on the Switch1, it remains standby. Switch1 doesnot switchover to be Active.
The configuration is attached with this mail.
Please help.
Madhu
Solved! Go to Solution.
09-03-2015 01:02 AM
Hi Madhu,
Sorry there is no automatic switchover.
Inayath
**********Please do not forget to rate the usefull posts*******
09-02-2015 11:16 PM
H Madhu,
Thats the expected behaviour.
when you reboot the active switch, the stand-by will take over. When the old active finish rebooting, it will be the new stand-by. At this point you can issue "redundancy force-switchover" to make the new stand-by active.
Inayath
09-02-2015 11:57 PM
Hi Iniyath,
Thanks for your reply.Is there any way for automatic switchover other than issueing this" redundancy force-switchover" command.
regards
Madhu
09-03-2015 01:02 AM
Hi Madhu,
Inayath
09-03-2015 01:45 AM
Thank you Inayath
