vss upgarde
masrawie11
Community Member
I'm trying to upgrade 6500 VSS from version 151-2.SY1 to 151-2.SY2.
I checked this link and there are too many ways for the upgrade. Not sure which one is right?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/vss.html#wp1133416
Reza Sharifi
The easiest way to upgrade VSS is by having a maintenance window and perform the following:
1-Copy the new image in both switches
2-change the boot variable to point to the new image
3-Save config
4-reboot both switches at the same time.
It will be all done in approximately 15 minutes.
