VSS
abeid
We got a 12.2(33)-SXH2a version of IOS 6500 switch with PFC3C Sup 720 and will that IOS image support multi SUP-720 for VSS configuration and will that support Multi chassis Ether channel Links aswell.
Giuseppe Larosa
Hai Giuseppe,
Thanks for the reply and that cleared my doubt about multi chassis Etherchannel but it says in the initial release of VSS it doesnt support supervisor engine redundancy within the chassis but in the later releases it does. So i wanna know does it support on 12.2(33)-SXH2a.
Prasanth
