08-09-2010 12:12 PM - edited 03-06-2019 12:23 PM
what is the most recent update about the VSS with two in-chassi supervisors on each 6509E?.
Is VSS with 2xsup´s in-chassi supported today?.
Thanks.
Solved! Go to Solution.
08-09-2010 12:42 PM
The most recent update when using SXI4 or SXI4a is support of multiple Sups per chassis.
You do want to use SXI4a, because there ware some MPLS components missing in SXI4.
Reza
Log in to Community
