VSS
darryl.hobbs
Visitor
We are looking into the VSS implementation. We have 3 6513 switches and would add 3 more running VSS. My question is do you need dual sup 720's in the switches when running vss? Can you use only 1 supervisor per switch while running VSS. On the website it had 2 per 6513 chassis.
a.alekseev
Level 11
Level 11
You can join in VSS only two switches.
For vss you need sup720-10G
You can use only one sup per chassis.
In future you can use two sup per chassis.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_white_paper0900aecd806ee2ed.html
