VTP question
Eric Hansen
Is there anything, short of an administrator, that can cause a switch running VTP Transparent mode to switch to VTP server mode? I dont believe there is but I wanted to be sure.
Trying to solve a mystery which I think professor plumb is guilty in the library with the fat fingers.
thanks
e-
francisco_1
Level 7
Level 7
unless someone actually change the mode on the switch!!
Borman Bravo
Only someone with access to the enable mode to the switch can do this, another possibility is perhaps a reboot with a configuration that wasn't saved, but it needs to be manually configured by someone.
Thats what I thought, thanks guys.
e-
