Vulnerabity SHA-1-based Signature
     How to fix Vulnerability- SHA-1-based Signature in TLS/SSL Server X.509 Certificate in 2960S
The SHA-1 hashing algorithm has known weaknesses that expose it to collision attacks, which may allow an attacker to generate additional X.509 digital certificates with the same signature as an original.
to my best knowledge as of now, there is no alternative yet other than to use a higher modulus (4096). Which means the below is the best you do:
crypto key generate rsa modulus 4096
ip ssh version 2
ip ssh dh min size 4096
