WAN Failover Cisco 1941
Narsimha Golla
we have two  point to point leased line connections one is Ethernet output  second one is serial output & cisco 1941 router it has 2 gig ports 2 serial port i want configure wan failover in this router is it support for this application?
Narsimha
John Blakley
Are you running a routing protocol or using static routes? If you're using a default route to toward your ISP (assuming the p2p line runs to the ISP), you can do 2 default routes with different ADs:
ISP 1 = 192.168.1.1
ISP 2 = 192.168.1.2
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.1.2 254
If you're using a routing protocol, it depends on what protocol you're using on how you could do this.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks for replay
I have small clarification if connect 1 ISP S0/0 & 2 ISP GIG0/0 is it give any interface problem
ISP-1  SE0/0   172.16.16.1  255.255.255.248
ISP-2  GIG0/0  172.1617.1   255.255.255.248
Narsimha
What do you mean interface problem? Can you clarify? Your addressing looks fine except the missing '.' for ISP-2. (172.16.17.1)
Narsimha
There is not any problem inherent in having different interface types (Ethernet and Serial) for outbound traffic and configuring failover.
Note that there may be some complexity in configuring failover on some interface types. For example when using static routes which point out an Ethernet interface it is possible that the next hop becomes inoperative (there is a problem with the next hop router) but the static route remains active in the local routing table. The solution for this is usually something like IP SLA or Object Tracking.
But there is not a problem about having one serial and one ethernet as outbound interfaces and configuring fail over.
As John says there are solutions which use static routing and solutions which use a dynamic routing protocol. The details of which to use and how to use them will depend on your own particular situation.
Rick
Rick
