wan problem plz help
cwynne001
i have vlan separated by a switch my pc's can communicate on their own lans but not across the wan can anyone help me please
router 1
Router#show run
Building configuration...
Current configuration : 1004 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
spanning-tree mode pvst
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
interface FastEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 10.0.0.2 255.255.255.252
 encapsulation ppp
 ppp authentication chap
 clock rate 64000
interface Serial0/0/1
 no ip address
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 network 192.168.2.0 0.0.0.255 area 0
 network 192.168.1.0 0.0.0.255 area 0
 network 10.0.0.0 0.0.0.3 area 0
router rip
 version 2
ip classless
line con 0
line vty 0 4
 login
end
router 2
Router#show run
Current configuration : 1000 bytes
version 12.4
hostname Router
 no ip address
 duplex auto
 speed auto
 ip address 192.168.1.104 255.255.255.0
 ip address 192.168.2.104 255.255.255.0
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 10.0.0.1 255.255.255.252
 encapsulation ppp
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router ospf 1
router rip
 version 2
ip classless
line con 0
line vty 0 4
 login
end
Jon Marshall
There is a fundamental problem in the design of this network and to fix it the original poster will need to implement a different design. The problem is fundamentally that this is an attempt to have the same layer 2 vlan in two different places connected by a layer 3 connection. And that does not work.
Perhaps the simple way to illustrate the problem is to think of a PC connected to the vlan on router 1. Perhaps it has IP address of 192.168.1.50. And it wants to communicate with a PC connected to the vlan on router 2 and perhaps this PC has IP address of 192.168.1.150. For them to communicate PC 1 must ARP for PC 2. But the ARP is a broadcast packet and router 1 does not forward a broadcast from a vlan over the serial interface. So PC 2 never receives the ARP from PC 1 and they can not communicate.
The easy solution to this problem is to make the IP subnets different on each side of the serial connection. Perhaps Router 1 could have networks 192.168.1.0 and 192.168.2.0 while router 2 has networks 192.168.11.0 and 192.168.12.0.
If the original poster really needs the same vlan on both sides of the serial connection then he needs to implement a technology like l2tpv3 which does provide the ability to connect a layer 2 network accross a layer 3 connection. See this link for some information about this
http://en.wikipedia.org/wiki/L2TPv3
Rick
Rick
