WAN redundancy using PBR with 2 PPPoE dialer interface
AirMax0518
      I have a network topology with 2 PPPoE dialer interface from 2 different ISP's and both are pro actively monitored by IP SLA's. Implementing Policy Based routing, LAN 1 uplink use ISP1 gateway and the latter uses ISP 2 gateway. However, I am trying to improve the set up where I want to have a dual redundancy on each LAN networks.
Example Scenario For LAN 1:
- LAN 1 networks primary uplink is ISP1 gateway then will switch to ISP2 as ISP 1 gateway becomes unreachable via IP-SLA tracking. As ISP 1 goes back up, then will switch back again to its primary uplink.
- LAN 2 network uses ISP 2 gateway as its primary link and switchover to ISP 1 as the primary link goes down.
ISP1 gateway: XXX.XXX.XXX.XXX/32
ISP2 IP gateway: YYY.YYY.YYY.YYY/32
LAN1 Network: 10.4.3.0/24 (gateway: 10.4.3.253)
LAN2 Network: 10.0.0.0/24 (gateway: 10.0.0.253)
      My problem is that I am having trouble with NAT as I am using both dialer (dialer 1 and 2) interfaces for each networks.
      Your inputs will be greatly appreciated. Thanks!
Current configuration:
redundancy
controller VDSL 0/0/0
track 1 ip sla 1 reachability
delay down 10 up 1
track 2 ip sla 2 reachability
delay down 10 up 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN 1 - CAT ISP
no ip address
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface GigabitEthernet0/1
description WAN 2 - ToT ISP
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
no cdp enable
! note: for testing purposes, i change Gi0/2 interface based on LAN1 or LAN 2 testing though I have L3 switch from downstream network to cater both LAN networks.
interface GigabitEthernet0/2
description LAN INTERFACE
ip address 10.0.0.253 255.255.255.0
ip nat inside
ip policy route-map PBR-TO-INTERNET
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
shutdown
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap callin
ppp chap hostname <ISP1@hostname.com>
ppp chap password 0 <ISP1passw0rd>
no cdp enable
interface Dialer2
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
ppp chap hostname <ISP2@hostname.com>
ppp chap password 0 <ISP2passw0rd>
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT-TO-ISP1 interface Dialer1 overload
ip nat inside source route-map NAT-TO-ISP2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX track 1
ip route 0.0.0.0 0.0.0.0 YYY.YYY.YYY.YYY 200
ip access-list extended HQ-NETWORK-TO-INTERNET
permit ip 10.4.3.0 0.0.0.255 any
ip access-list extended MANSION-NETWORK-TO-INTERNET
permit ip 10.0.0.0 0.0.0.255 any
ip sla auto discovery
ip sla 1
icmp-echo XXX.XXX.XXX.XXX source-interface Dialer1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo YYY.YYY.YYY.YYY source-interface Dialer2
ip sla schedule 2 life forever start-time now
route-map NAT-TO-ISP2 permit 10
match ip address MANSION-NETWORK-TO-INTERNET
set interface Dialer2
route-map NAT-TO-ISP2 permit 20
match ip address HQ-NETWORK-TO-INTERNET
route-map NAT-TO-ISP1 permit 10
set interface Dialer1
route-map NAT-TO-ISP1 permit 20
route-map PBR-TO-INTERNET permit 10
set ip next-hop verify-availability XXX.XXX.XXX.XXX 10 track 1
set interface Dialer1 Null0
route-map PBR-TO-INTERNET permit 20
set ip next-hop verify-availability YYY.YYY.YYY.YYY 10 track 2
set interface Dialer2 Null0
0 Replies 0
