01-15-2016 05:53 PM - edited 03-08-2019 03:25 AM
hello
thanks for your time . i am quite new to ccna routing and switching self study .
can i connect Cisco router 1812 to Cisco router 1814
In 1814 i can have DTE-DCE module but in 1812 there is no port for it and i cannot install any module in it . there is no space in it
i like to know how i can connect two 1812 to each other or 1814 to 1812 if its possible . which ports i will use to make WAN connection between them .i am practicing on my home lab
thanks again
Solved! Go to Solution.
01-15-2016 06:28 PM
01-15-2016 06:19 PM
Unfortunately, 1812 does not support any WAN module. It is fixed configuration.
I suppose you meant 1841 instead 1814. 1841 supports plenty of WAN modules.
I suggest you to connect two routers by Fastethernt interfaces to simulate WAN.
Please take a look at the link below for more information.
http://www.cisco.com/c/en/us/products/collateral/routers/1801-integrated-services-router-isr/product_data_sheet0900aecd8028a95f.html
Hope it helps,
Masoud
01-15-2016 06:25 PM
i cannot connect 1812 to 1841 for WAN as i understand from above link . thanks
01-15-2016 06:28 PM
No, 1812 does not support any serial interfaces.
Masoud
01-15-2016 06:38 PM
and 1812 cannot connect to 1812 for WAN through crossover cable
01-15-2016 06:50 PM
1812 is designed for metro connection. You can connect two 1812 routers by Ethernet crossover cable. It has 8 fastethernet interfaces for internal network and 2 fastethernet interfaces for external network( let say WAN or metro). Use those two interfaces for connecting two routers( simulating WAN connection instead of using serial) and use other 8 interfaces for practicing VLAN and interVLAN routing.
Masoud
